Many of you know I had a running problem with my 1990 Festiva L 5-speed. I replaced the crankshaft position sensor and adjusted the throttle position sensor and now she runs like a dream. But I have another problem with the same car.
When the car is warm she idles at a about 900-1000 rpms. When I come up to a stop light and hold in the clutch the rpms drop to about 400-500 rpms.
If I put the car in neutral and let out the clutch the idle goes back up to where it should be. But the moment I step on the clutch the idle drops.
I tried adjusting up the idle but it makes no difference. The idle still drops to the same place.
It hasn't died on me yet but it seems that it might if I hold the clutch in long enough.
Has anybody encountered this problem before? Any help would be appreciated.
Thanks
Thanks
