So there seem to be 3 coolant temp sensors, and they only one i can find in the haynes manual is the one on the intake manifold. I think this is the main sensor and controls the temp gauge as well as sends a signal to the ECM.
The second one is in the head, just on the head side of the tstat. I believe this is a simple on/off switch for the radiator fan.
The third is in the tstat housing, near the upper rad hose. it is a single "male" type spade connector, and the plastic surrounding mine is busted up a little. My question is: what does this one control?
Ever since my B6 swap my car has been running cold, and when its luke warm it cranks for a while before it fires (when its cold or real hot it fires on the first crank, and if i hold the gas in a little while its luke warm it fires better). I replaced the tstat (which was a dual-stage) with the dual-stage tstat that was in my B3 (ran at normal op temp) and now the B6 will heat up to 1/8" or so above the cold line, but it still has the weird starting problem. So i replaced the CTS that is in the intake manifold with the one that was on my B3, and no change. Thats why i'm wondering what the third temp sensor is for...
any ideas? thanks
any ideas? thanks
