I pulled my turn signal/wiper swith out of my 91 Festy thinking I had a wiring problem but I created another. When I put it all back together, my automatic seatbelts do not work. I checked the fuse and it did blow. Every time that I replace the fuse in the fusebox, it immediately blows. I think I may have damaged the wiring for the automatic seatbelt on the signal/wiper switch but I cannot identify which wires that connect to the signal/wiper switch look for. I attempted to remove the fuse box and see what color wire attatches to the 30 amp seatbelt spot but I could not get the fuse box panel out.
Does anyone know what color wire goes from the signal/wiper switch on the steering column to the fuse box? Something is definetely shorting out.
