im trying to remove my FPR from a 96 EFI Aspire. I have disconnected all the fuel lines, and removed the two 10mm bolts from that mount the regulator, but it still wont come free. I can twist it around, but its still being held in. Is there an internal Oring or sumthing?? How can i remove the unit?
fuel pressure regulator
there is an o-ring on the inside part, but it just slides out. Get a small screwdriver in there and pry, its pretty thick metal you shouldn't break anything.~Nate
Current cars:
FOTY 2008 winner!
