plug and play?
  • plug and play?
    a few things, are they plug and play?
    i got a 1989 L carbed.
    the tach cluster.
    5-speed trans.
    rear wiper (w/hatch)
    tilt column(w/int. wipers)
    i think thats it.
    but 2 more ?'s
    1. how do i check my tranny fluid?
    2. how do i tighten my hand-brake?
    it'll do the 1/8 in 13.7, spin tires, and make all my drunk buddies giggle.
    "I like a Festiva because there's less car to get in the way of the driving experience"
    I don't know if the tilt is plug and play but all the rest of the iems are. The fluid is checked on the bottom of the speedo cable attachement in the tranny. And the hand brake is tightened inside the car under the brake cover.
    93 GL modyfied!!!
    :fish:
      I don't think all '88-'89 are plug and playfor the tach clusters. From what I've read on here if it has rear defrost odds are it has the wiring for the tach but some are missing these wires.
      ~Scott
      1989 Festiva L EFI
      2010 Toyota Prius
        I have converted both types 88&9 with wiring in place and without, and still own them. Tilt and inter wipers are a go with any 88&9 car. No extra wiring required. The rest of the items are mostly if you have the rear defrost as suggested before. I have only had one odd car that didn't follow this rule. Wiring for the rear wiper is attached to the blank plug on the cluster cover. Rear wiper is the hardest install requiring the keyhole shaped hole for the washer, routing the hose through the body down to the washer reservoir, and lining up the oval hole cutout for your motor shaft to go through. Easiest way is swap the hatch, or make an exact marking, and also shape template off donor hatch. I have converted 3 so far to all LX options. PM or email me if I can help.
        Michael
        Have owned 9 so far
          The Hand brake cable can be adjusted by removing the small plastic cover....with your eyes follow the finger grips down the handle and look for the nut at the end of the cable.
          CAUTION: This is not normal maintenance...either the cable is shot....the brakes are extremely worn...or the adjusters are not funtioning.
          Joe Lutz
          The SKATE ..... 1992L 5spd
            I have a hatch with rear wiper if your interested. PM me and we can work something out.
            ~Scott
            1989 Festiva L EFI
            2010 Toyota Prius
              Oh, and while adjusting the parking brake, watch that the small clip that ratchets the adjustment doesn't fly off. Takes a 10 mm socket to adj nut. Don't adjust too far and snap off end of cable assy. I have recently heard that they may have become totally unavailable as a brand new part. (Roger @ FMS). :shock:
              Michael
              Have owned 9 so far
                So so right, but, when I needed to pass inspection, the guy said my ebrake did not function properly. I thought he was nuts, but drove down the street, tightened it at the handle, came back, and blew his mind at how tight the ebrake was in 5 minutes! Passed, went down the road, loosened her back up, and kept on rolling!
                  yeah the hand brake was easier to adjust than it is to drive my car.
