is ther a easy way to remove my bumper or do i have to get at those 3 stubborn bolts at the back. are there only 3 bolts on each side?
bumper removal?
bumper removal?
Mike, AKA the sasquatch
1990 LX, bp+T/g25mr, 9psi dynoed at 194HP, turbonetics t3/to4e 57trim, haltech E6X standalone, 550cc injectors, turbosmart wastegate, synapse BOV, walbro 255 fuel pump, aeromotive FPR, AEM wideband, 3 inch exhaust, huge FMIC, 9LB flywheel, 6 puck clutch and way more parts that im forgetting i installed lol...Tags: None
on mine, if you are asking about the front there are three on each side. not sure about the back bumper.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
ok thanks. i was asking about the front... forgot to put that in the post.
Besides the 3 bolts on each side, the harder part is those stupid little side supports that tie the tail edges of the bumper to the underbody. I have not been able to take any of them apart. The nuts rust up solid, and the steel ties are so thin they just twist and then break. One of the bolts on the driver's side is hard to get at without taking off the inner wheel cover, and even the windshield washer bottle. (Not required, just easier.) But that's about it except for the wiring. There is no easier approach to it.Thricetiva replaced Icetiva as the new ride
Icetiva-3-race-car-build
