1993 festiva, BP, f-series tranny
the other day i drove it home and parked it in the driveway, the next day i got in it and it cranked over but didn't fire, today i got checking it out, it has spark, no fuel pressure
so i go back to the fuel pump, first tests show power at the pump, causing me to beleive a faulty fuel pump, so i replaced it with a known good pump, put everything back together, still doesn't fire
i pulled the fuel line off the sending unit, and no fuel comes out whether the key is on or off
so i know my fuel pump is not turning on, i'm sure i have a good pump installed
so my question is, there are 4 wires going into the sending unit:
red - there is power that turns on/off with the key, then fades out as if to shut the pump off when sufficient pressure is there
yellow
black w/ white stripe
black
what does each wire do?
this has really got me stumped since it drove fine to where it sits now
yellow
black
