I've got a 92 festiva with 216,543 miles. It uses 2 Qts a week an its leaking it from the left side where the head and the block & timing cover meet is it the timing cover gasket or ?
bad oil leak 2 Qts a week
It sounds like he's facing the engine from the front so i would say crankshaft seal,no timing cover on left side of engine.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
Its not the timing cover . The leak is lower just to the left of the exhaust manifold but above the coolant manifold to the lower radiator hose. There's a recessed area were the timing cover and the block & head meet thats were it's coming from.5 titled an 2 untitlable festiva's
an a load of parts
:?:Originally posted by elcamino1It sounds like he's facing the engine from the front so i would say crankshaft seal,no timing cover on left side of engine.
I'm pretty sure everytime I've opened my hood and looked, the timing belt cover was on the left side(if facing the engine from the front).
Most likely it's the cam seal since you have oil that high. Pull the timing cover off and you'll be able to tell where it's coming from. The timing gasket isn't meant to be an oil gasket. It's basically just a dust cover.
^^ I'm pretty sure everytime I've opened my hood and looked, the timing belt cover was on the left side(if facing the engine from the front).
Yes on your left side,but in the engine bay timing cover is on the right side.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
It's just a standard school of thought to reference everything as if sitting in the drivers seat. Driver's side=Left Passenger side=RightOriginally posted by elcamino1^^ I'm pretty sure everytime I've opened my hood and looked, the timing belt cover was on the left side(if facing the engine from the front).
Yes on your left side,but in the engine bay timing cover is on the right side.~Scott
1989 Festiva L EFI
2010 Toyota Prius
The oil under the valve cover isn't under pressure so it's less likely to leak copiously than one of the engine shaft seals. The timing belt cover comes in two halves, the upper and lower. It's possible to remove the upper separately for inspection if one is careful.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
A ggod thing to check if your taking the valve cover off is the end of the rocker arms rods. The inside of the rocker arm rod has pressurized oil, the ends of the are pluged...not a common problem, but it does happen, the plucgs on the ends leak and squiret HP oil that will blow oiut the valve cover seal. However, this failure will coincide with alot of valve train noise.Joe Lutz
The SKATE ..... 1992L 5spd
The belts will sling oil all over, so where its coming from doesn't mean that's where its leaking from. Pull the timing belt cover off clean off the oil and run it for awhile and keep a close eye it on it. Then replace all seals and gaskets.sigpic
^ nosigpic
