For my '93 Festiva will I need to remove the battery and tray to access the washer fluid pump for the windshield? Tried using it yesterday and it's not pumping anything, and yes I even fulled up the tank and then tried it again.
Washer fluid pump
its accessed through the splash sheild above the drivers tire.
personally, when my pump quit working, i took it apart, got the pump to work, but it started to leak, and i realized, who needs this anyway? and yanked the whole system out.~Nate
Current cars:
FOTY 2008 winner!
Can't remember off the top of my head, but when mine quit working, it turned out to be that some dirt made itt in there, went through the hole line, then clogged the nozzle on the hood. Quick and easy check is just to raise the hood, pull the hose from the nozzle, and then try it!Contact me for information about Festiva Madness!
They sell the pumps at Advance auto.
Originally posted by skeeters_keeperwho needs this anyway? and yanked the whole system out."FLTG4LIFE" @FINALLEVEL , "PBH"
