Timing marks for Valve Timing
  • Timing marks for Valve Timing
    I am trying to figure out if my valve timing is off and just wondering if I have to pull the crank pulley off or if there are marks on the pulley that are supposed to line up somewhere. I'm taking it all apart tomorrow, but if I don't get any responses I'm taking off the pulley and doing a timing belt. Thanks.
    "If you're not first you're last!" -Ricky Bobby
    -91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
    The little Festy that could...and did!
    (Gone on to a new life)
    -90 Ford Bronco II Eddie Bauer
