My whipers and blower motor only work sometimes and they go out in pairs. I'm havin a problem finding what is wrong. I checked the grounds to see if they were loose or dirty and they were fine. I was trying to find the power ends, but I'm having trouble determining if its the swtiches or not. I'm open for any ideas or even ideas on how to hard wire the whipers and the blower motor to a seperate switch.
Electrical Problems
electrical problems
If your wiper and blower motors work only at times you should check the fusebox connector where the fuse plugs in.the little plug contacts in the box can get corroded and sometimes it even weakens th spiring clap action of those little contacts in the fuse plug. clean em and spray em wit wd-40 or better blaster PB.
nice ill look there, i think its in the key position though, cause if it doesnt work i just turn the key a little bit and it works again, but it cant hurt to clean rust off"If you're not first you're last!" -Ricky Bobby
-91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
The little Festy that could...and did!
(Gone on to a new life)
-90 Ford Bronco II Eddie Bauer
^^Could be key related....When the key is in the ON position...12V leaves the key as a blue/red wire and splits into two black/red wires that supplies bothe the wiper and blower fuses....if the systems work with a wiggle of the key....seems like the key switch or something close to the key assembly.Joe Lutz
The SKATE ..... 1992L 5spd
thats what ive been doin if it doesnt work on start up, seems to do the job, no more worries"If you're not first you're last!" -Ricky Bobby
I had that problem with my wipers. Checked everythng I could think of. Took the wiper motor off and apart. Not the problem. Now my baldes are askew. It's the ignition key. Just squirt some oil or WD-40 into he keyhole. Worked for me.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Isn't that supposed to be harmful for the switch?I have heard that before, but do no know......Originally posted by WmWattJust squirt some oil or WD-40 into he keyhole. Worked for me.Contact me for information about Festiva Madness!
If I remember correctly, the actual ignition switch is a sealed plastic unit behind the keyhole so squirting lubricant into the keyhole does not lubricate the switch. I recomment taking the ignition switch apart and cleaning things up where the problem lives. I also recommend silicone spray lube and not wd40 or other oil based lubes. Good luck!I'm going to come at you like a spider monkey!
White 1993 L plus, 5 speed - 47k miles
* Aspire brake swap, 14" Miata wheels & Tein coliover suspension
