hey I have a 93 head on my 88 and the freakin hla's click worse then an amish pirade can i swap my solid rockers in and throw the hla's through the window at a ford dealer? will it hurt any thing? sorry about the attitude guys but i am a little high strung right now... My aspire is freakin totaled.... head on with a guard rail at 55... turns one car to junk pretty quick....
hla swap out attn: slim JIM
you need (should use) the solid lifter cam to run the solid rockers. the temper of the lobes is different between the two. You ok? wreckin' the assfire sucks! although, now you have a great parts car for an Aspire brake swap...
Jim DeAngelis
Auto-rx fixed my HLA until winter hit. I guess two treatments didn't clean them well enough for the o-rings had died.
So I dropped the $80 and replaced them all. I guess in retrospect I could have found the one or two that were bad and replaced only those.www.dantheoilman.com
Go ahead and ask me why
Depends on if it's just the external o-rings that are bad or if it's something internal causing problems.
Or a passage way somewhere.www.dantheoilman.com
