Well today I got the festy running.. this morning first thing connected the rods to the crankshaft (used plastigage), put oil pan on, timing sprocket, my head was already done and ready to go, intake and exhaust manifold,timing belt, and air intake stuff. Added fluids and had it fired off at 5:30p, and she ran like a charm!!! a lot better than 3 cylinders when it quit 4 months ago.
Ran it as specified in my trusty haynes about accel to 50 nph and decel to 30 mph etc....
One thing is after running a while my check engine light came on and i ran the codes when i got home and they are 15 and 17. O2 sensor info for both... this didn't come on before it quit...??? any way to check to see if the O2 sensor working properly before I go and buy one?
Finally just put a day aside to work on this lil beast and now its a going!
Then I had my cheapo sunpro II tach from autozone and got it installed as well! Still need to adjust my idle speed though. When i am up to temp and the hood is open my engine does a very mild surge...? increased rpm like 50 ish..at about 2 seconds frequency. any suggestions?
