the right from axle is shot. i was wondering how hard that is to replace myself and if i should go junking for one or buy a new one?? any advice??
front right axle replacement??
New one is less than $70 usually, and much better off going that way. You will really want to do both sides, though, if you do one, the other will go bad QUICKLY anyway.
Jack up car, put on stands.
Remove tires.
Have friend step on brakes, I THINK the axle nut is 21mm? Use a breaker bar, and some grunting(cussing) to get it off(sometimes it is hard to get off)
Hard part is over, crack a beer.
Remove tie rod end.
Some say remove ball joint, I like to remove the 2 knuckle to strut bolts, after unclipping brake line from strut.
Put pan under axle where it mates to trans to catch trans fluid.
Tap on axle where you removed the 21mm bolt with a rubber mallet, this breaks axle free of knuckle, swing knuckle out of the way.
Sometimes the axle will come out of the trans with a good yank. If not, a LARGE flathead screwdriver, wrapped in tape, to pop it loose. If you are not replacing seal, be careful not to damage the existing one.
Pull old axle out.
Time for a beer.
Reverse procedure, use a torque bar to tighten axle bolt to between 116 and 174 ft lbs( from haynes, a wide range if you ask me, I think I usually settle for 130 or so.)
Enjoy the silence of no clicking clacking while you turn, AFTER the beer wears off
Piece of cake, with practice about 30-45 minutes to do both sides.....Contact me for information about Festiva Madness!
NAPA told me recently that they're out of cores so require that customers send in theirs for rebuilding. They might also require a minimum batch size of about 20 to make it worth their while.88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
autozone and advanced auto usually have them around here, call around.I like carquest. Also, rockauto usually has them online. You could check festivamotorsports as well....Contact me for information about Festiva Madness!
I'd recommend putting that new CV seal in, and using new trans fluid. If possible, use a new axle nut, too.
If you don't already have one, get the Haynes manual for Festiva/Aspire. It's best to have that plus a Ford shop manual. If you plan on keeping this car and working on it, they are indespensable.
You're better off disconnecting the balljoint, unbolting the knuckle from the strut could alter your wheel alignment. Also I'm pretty sure the axle nut is bigger than 21mm.Axlander9289, brother of ThisVelologist
Festivas past:
Aqua '92 Festiva L - Sold "Dale"
White '89 Festiva L Plus - RIP "Dudley"
White '93 Festiva GL - Sold to thisvelologist "Frito"
Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
Current Fleet:
Aqua '93 Festiva L with Aspire brakes "Dale Jr."
Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
White '15 Ford Transit Connect
Originally posted by Safety GuyI'd recommend putting that new CV seal in, and using new trans fluid. If possible, use a new axle nut, too.
Karl
Originally posted by Axlander9289You're better off disconnecting the balljoint, unbolting the knuckle from the strut could alter your wheel alignment. Also I'm pretty sure the axle nut is bigger than 21mm.. Probably not a good idea to go that way. I would recommend, if removing the ball joint from the knuckle, using a LONG piece of steel pipe to make it easier....
