Hello all,
Had the outer CV joint on the passenger side come apart on me yesterday
which meant an expensive tow job home.
Anyways.... here's the problem: the axle just doesn't want to come out of the transmission. I've tried several of the suggestions that I found here on the forum to no avail.
If I can get the other axle out is it possible to reach through to the end of the axle and try to pound it out? Would that even be advisable?
Any suggestions would be greatly appreciated.
which meant an expensive tow job home.Anyways.... here's the problem: the axle just doesn't want to come out of the transmission. I've tried several of the suggestions that I found here on the forum to no avail.
) I even rented a fairly heavy slide hammer and so far the axle hasn't budged.
... but it's still attached to the transmission
