Outside temp gauge plus clock gadget
  • Outside temp gauge plus clock gadget
    My dad had a little gadget a while back that was about 3" wide and 1" tall and was a outside temp gauge thermometer with a clock. I can't seem to find one (tryed ebay etc)..
    anybody have one and where can i get it? Maybe i am not seaching ebay correctly..?
    -Aspire brake swap COMPLETE!
    went to "gadgets and other electronics" in and searched that way. heres what i found:
      I like that , really cool !!
      I have a blue back lit clock on my dash , but no temp , I may need to get one of those .
      HD2500 Duramax Chevy
      Z28 LS1 power 500 +
        Nice! I think I'm gonna have to pull the trigger too!
        89SX funtop! Fully loaded!
        RIP 90LX
          who needs GPS, navigation,and heated seats anyway. get a map, eat a bowl of refried beans, get a few gadgets like this and you pretty much have a 2008 BMW 550I:
            Some thing kinda like that @ advance auto stores. Around $30
            Going old school...
              Thats really cool, I'll have to find one of those
              "If you're not first you're last!" -Ricky Bobby
              -91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
              The little Festy that could...and did!
              (Gone on to a new life)
              -90 Ford Bronco II Eddie Bauer
                http://tinyurl.com/3f5b9l
                I'd rather roll in a z4m
                  Well, i just got it in the mail. Where do you think would be the best place to mount the outside temp sensor? Where are they on other cars?
                    I think they are usually mounted in front of the radiator to prevent false reading from the engine comparment heat.
                    ~Scott
                    1989 Festiva L EFI
                    2010 Toyota Prius
                      got mine today too
                      RIP 90LX
                        I don't know if my outside temp wire will go from the dash, through the wiper firewall (may drill a small hole) and to the front of the radiator behind the bumper.... what about the front Left corner by the horn?.... any other suggestion closer to the bottom of the windshield? maybe the wiper area...
                          Originally posted by stefan View Post
                          got mine today too
                          SWEET! I think i am going to hard wire the backlight (came w/ cig lighter plug in) and mount on that little 5" piece of dash trim right in the center of the vehicle at the base of the windshield... mount the wires through the firewall there so i won't have to disassemble the dash.
                            so what would be the best way of wiring it to the car cause well i don't want to have it plugged in to my lighter and well it doesn't work atm anyways
                            1989
                            Ford Festiva L
                            Automatic
                              well, since it is 12v, i am going to cut it and attach it to my headlights (i believe red/blue wire..??) and so when i turn the lights on it the backlight will come on. The cord from the gadget to the lighter has 2 wires, one ground, one hot.
                              I have a tach install, and so i'll tap into the same wire that turns on my light for the tach when i turn on my headlights.
