HELP!! Emission/Vacuum hose diagram or blowup
  • #16
    7 years difference from our cars newest model.....may be some differences..or a lot.
    • #17
      ^^ Not to mention that it's a European version. If you look at the pics of his engine bay, there's a good bit of difference between his EFI car and our EFI models. Many more vacuum lines and his even has an EGR valve.
      I looked up the Vacuum diagram for a [US] 93 model and it literally only shows 5 hoses. The one from the fuel tank to the purge canister, the one from the purge canister to the purge solenoid, the one from the solenoid to the throttle body, the one to the fuel pressure regulator, and the PCV. That's it (not even the brake booster hose) :-?
      WWZD
      Zulu Ministries
      • #18
        Thanks Zanzer for your help,
        I will look into it. Where is the PCV valve located?
