Anyone Know of a Good Engine Removal Tutorial?
    What did you do?
    Originally posted by FRANTIK
    Thats weird, I just did it for like the 6th time today. with ease.
      every time i have pulled my engine it has been without the tranny
        Please post a quick synopsis of how you did it.
          First, get some different colored tape or zip ties and use them to mark wires, vacuum lines and hose locations that will be disconnected.. especially the fuel lines (I've reversed them a few times and it's just annoying) support the engine with a hoist, drain the coolant, disconnect all hoses, vacuum lines, fuel harness, sensors, unbolt the passenger side motor mount, exhaust flange, the starter, and ALL bolts around the bell housing don't miss the 10mm bolt on the very bottom of the transaxle. lift and wiggle the engine loose from the transaxle. Be patient, if you have everything disconnected, it will move away about 2"... then it will pop loose.. reverse the process on installation...
          Did I miss anything guys??
