K so I just got my baby.
It is the base, base, base model of the 1994 Ford Aspire 2D.
This is the first of may foreseeable issues:
My instrument panel is... well wonky.
The speedometer does not work.
The odometer does not work.
The temperature gauge flutters.
The airbag light flashes, then stops when I hit a bump and starts flashing again after the next bump.
The fuses are good (Checked everyone of em in car)
Have not checked the 80 amp under the hood. But I'm forced to assume that if it was bad then there is much that would not work.
So my question is this.
What needs replaced? Is the whole panel bad and needs replaced or is it something like the VSS?
Any advice or suggestions welcomed, PM or reply.
Thanks much!
Thanks much!
