I just purchased a '90 Festiva with a 5 speed. Driving, it makes a growling, grinding noise from the front end. You can jack up either front wheel and let it spin. The noise is the same from either wheel. There doesn't seem to be any lateral play in either front wheel.
If this were a rear drive car, I'd suspect differential carrier bearings.
Is the problem likely in the transaxle or in the wheel bearings?
How can I confirm?
How can I confirm?
