Gasket or no gasket? When I tore down my B6 there was only some white RTV.. My lower set came with a gasket... do I use the gasket or the RTV?
Also which RTV would be the best for the oil pan... my set did not come with a gasket.. permatex ultra black? I assume I put a bead between the splash shield and the block and another bead between the splash shield and the pan?
