Warped rotor?
  • Warped rotor?
    My steering wheel shakes when i'm on the brakes... that means I have a warped rotor, right?
    89SX funtop! Fully loaded!
    RIP 90LX
    usually if you have warped rotors the brake pedal will feel like it wants to move up and down as you press on it
      I think I'd be doing a thorough suspension check. I would think even a tie rod end would do what you are describing Stefan. Look at your tires. Any uneven wear or chopped?
      #2 .....Cheesehead
      #3 '91 White - Donor Car
      #4 .....Montana Project
      SOLD----Levistiva for $1500
      Bought her back for $450
        hummm... that makes more sense... I wonder what the shaky steering wheel means then?
        RIP 90LX
          I know my rotors are warped. If I'm trying to slow down quickly from say..100km/h..I get some pretty bad shaking. Also when I'm just creeping up to the light I can feel the brake pedal sort of 'pulsing' as I come to a stop.
          If that's what yours are doing, then I'd say you have warped rotors..and you could probably get them machined down.
            my book says it could be the wheel bearings or the tie rod ends as levitan said.
            87 rx7
            92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
            94 caddi deville
            99 f250 LD 4x4 12 inch lift on 38s
            i need more festies.
              Tires, tie rods, tie rod ends, LCAs, all new abut 6 months ago...
              I'll have to get the car in the shop and check everything over.
              One thing I KNOW is blown in the front is my struts.
              RIP 90LX
                If you park your car with the brakes very hot, sometimes the pad linings will "track" onto the rotor and leave a slight deposit. When you apply the brakes, everytime the pads pass this spot on the rotor, it will transfer a shake into the steering wheel.
                  Sounds like rotors to me.
                    If it is your rotors don't replace them with those cheap china made ones or you'll have the same problem again once you get them heated up,go for some of the best,Bendix or Rabesto,cost a little more but last a lot longer.
                    99 Dodge Caravan SE
                    95 Taurus SHO auto 265hp
                    94 F150 351W auto (for sale)
                    95 Honda 1500 Goldwing SE
                    95 Iszuzu Trooper LS
                      Rotor Test
                      Ride the brakes down a long...long...hill.
                      If the throbing, in the steering wheels get worse as you descend the hill its the rotors.
                      Typically, the hotter the rotors, the more severe the throbing in the steering column.
                      Tie rods....wheel bearings.....missing wheel weights...usually do not need the brakes applied to rear their ugly heads.
                      Joe Lutz
                      The SKATE ..... 1992L 5spd
