Timing Belt -Original Make?
  • Timing Belt -Original Make?
    Hello Folks.
    '96 Aspire, 160 K Km.
    The timing belt is labelled : " Gates , Made in Korea "
    Is this belt factory original?
    It appears to be in good shape.
    I'm wondering if belt has been replaced.
    Thanks,
    -JS
    Question Authority.
    If you can read anything on it most likely it's not the original. I think the original has a brand name that starts with S.. but it's been a while.
    91 rusty Festiva 260k
      Yes, i believe that Gates is not an OEM supplier, just for the aftermarket replacement. But DAMN they make good belts if mine is anything to go by; 30k OVER the replacement interval and didn't break.
      imo just replace yours if not sure about the age.
      Mark S.
        I have the original timing belt off my Festiva.
        It has the following written on it:
        047 ||
        B63012205E DO NOT CRIMP INTTA Power Grip MADE IN JAPAN 107Y216 048 8-48 ||
        049 ||
        The replacement belt I bought for $35 CDN and installed on 06Apr01 at 94,150 km is on the car now so I can't say what's written on it. I still have the box it came in which says "CAM DRIVE BELT PB-551-5" with a distributor's sticker which says "CD-141 made in U.S.A" and universal product bar code "0 37256 3746 7". I must have got it at Canadian Tire because it has a sticker with their code 17-1227-8 on it. No manufacturer's name anywhere.
