Engine won't fire
  • Engine won't fire
    I Have a 1990 festive and 2 weeks ago I sprayed the engine with engine cleaner and water and now the engine won't start. I have no fire at the coil. I have replaced the coil with another one and changed out the ignition mod but still have no fire. What else causes the coil to fire? Any ideas that may help??? The car was starting and running fine till I washed the motor.
    Thanks,
    Distributor cap, wires and rotor, maybe?
    May have filled the distributor.
    it runs so sweet
    91 L 5spd
      Try spraying sme WD40 in the dist and then wiping it out with a rag.
      93 GL modyfied!!!
      :fish:
        maybe soaking the fusible links on the fenderwell caused a problem...shorted them out.
          Ha this is what mine is doing too after do the same thing. I wonder if he got it fixed?
          Rodney
          1991 FI 5 Speed Aqua Blue
            check the connector (low voltage) at the distributor. Disconnect it, clean it out and dry it, reconnect it. It's responsible for sending the trigger pulses to the ign module, and the module drives the coil.
            Jim DeAngelis
            kittens give Morbo gas!!
              Didn't fix mine.
              See other thread.
              Rodney
                I'll update both threads on my solution.
                Time. I think.
                Jump in this morning, after all I did yesterday and all the heat and sun drying and it fires up first turn of the key.
                Rodney
