okay so my oil is empty...so yeah when my engine started making the noise i tried not to drive it well i decided to go to the movies today so i drove it and it sounded really bad so i checked the oil and it was empty what could be causing this problem...
engine sounds like sewing machine...
Originally posted by gothguydante View Postokay so my oil is empty...so yeah when my engine started making the noise i tried not to drive it well i decided to go to the movies today so i drove it and it sounded really bad so i checked the oil and it was empty what could be causing this problem...
It might not be empty. Nothing usually shows on the stick at about 1 quart low or so. Fill it up and then check it often. Is there smoke from the exhaust or any visible leaks?~Scott
1989 Festiva L EFI
2010 Toyota Prius
If it's only on start ups it could be valve seals leaking into the cylinder while it is sitting. Then when you start it up it burns of and quits smoking.
Edit: Ok so I just read back through and noticed a couple things you said. You recently did a oil change. Any chance maybe you didn't get enough oil in it then? Also Somebody put oil in the radiator? and it blew the radiator? did it happen to overheat at that time? Maybe it could be a head gasket or warped/cracked head causing a leak into the cylinder. I would thing you would have other symptoms too if this was the case but just an idea.Last edited by scottxd45; 05-04-2008, 01:53 AM.~Scott
1989 Festiva L EFI
2010 Toyota Prius
yes but like you said it's leeking cause it only smokes if it sits over 2 hours without being started.. you should come down and check it out... j/k i went up to terre haute last year it's nice my girlfriend wanted to move up there...but yes the car.. i don't know what to do.
1989
Ford Festiva L
Automatic
give it to me and start over.....lol"FLTG4LIFE" @FINALLEVEL , "PBH"
What to do depends on how much time/money you want to put into it. If you think it's valve seals or something leaking into the cylinder you need to replace the seals and maybe the valves. Also if you pull the head to do that have the head checked out at a machine shop to make sure it's good before reinstalling it.
Does the noise go away after topping off the oil?~Scott
1989 Festiva L EFI
2010 Toyota Prius
If it's leaking into the cylinders they only seals I can think of would be the valve seal or the head gasket (maybe someone else can confirm this). And like I said if the head gasket was bad I would thing you would also be getting other symptoms like maybe overheating or vacuum problems so I would put my money on valve seals.~Scott
1989 Festiva L EFI
2010 Toyota Prius
