I was wondering about how to tell if the thermoswitch (turns cooling fan on and off) coming out of the water outlet/thermostat housing is bad. According to the haynes manual, it says that there should be NO continuity between the prong and the base when the engine is cold and continuity when hot.
Another point they mention in the manual is that when the ignition goes on, without starting, the cooling fan should come on... well, as my cooling fan switch is likely bad, i have just disconnected it and the fan still comes on all the time. so what is the correct way? should the fan come on even when the engine is cold and the ignition is on (not started) or not?
