grease fitting on lca's
  • grease fitting on lca's
    has anyone put grease fittings on their lower control arms?
    if so, did you put them on the bottom or the side on the ball joint?
    1960 willys pickup
    1967 jeep cj5
    1988 festiva
    1989 festiva
    1990 festiva for parts
    1991 s-10
    I've never done this. You'd have to drill a hole and tap it to screw a grease fitting in, right?
    Karl
      i have zerts in my tie rod ends but not LCA's
        Done it, put the grease fits at the bottom, use moly grease. and yes you have drill it very slowly and also put some grease in the drill so you may catch all the metal shavings.
        Tap it also with grease, clean everything, fill with grease and your good to go.
        I did cause when I changed mines, just for curiosity, I removed the dust cap and find no grease at all.
        Sorry for the spelling, but some one took away the ABC botton
          thats what i thought, to do it on the bottom. i've gotten tired of replacing them every two to three years.
          is their a reason to use moly grease instead of regular lithium based greases?
          1960 willys pickup
          1967 jeep cj5
          1988 festiva
          1989 festiva
          1991 s-10
            The Google toolbar with spellcheck is your friend!
              The moly grease is for high pressure applications so it is a lot better than the regular litihum.
