Rotors and Front Bearings
  • Rotors and Front Bearings
    My Festiva is a 1993. I am thinking I would be good with any manual
    from 1988 to 1993. Am I correct in thinking that?
    I took my car to the dealer because of the special tools needed. I
    told them to check out the bearings because that was what I suspected
    the noise I had was. They replaced some bearings
    and said the others were fine. The car was still making the same
    noise. They told me it was the differential in the transmission.
    They said it could last a day or the rest of the life of the car. It
    was recommended to me to get a used transmission, which I did two
    years later after listening to that stinking noise the whole time!
    After buying a used transmission and paying to have someone put it
    in, I found out the transmission I just bought was a 4 speed when
    it was suppose to be a 5 speed! Then the car made the same exact
    noise! A friend of my helped me put my old transmission back in and
    we noticed the bearings on the front driver's side were totally shot!
    So I took it back to the dealer and they charged me $275 to replace
    the two bearing on the front driver's side which should have been
    replaced two years ago!
    This is why I am so ready to do all my own work!
    Anyone else have trouble with such things?
    I just did mine a couple of months ago. It's not easy but it's not impossible. I couldn't have done it without help from members here or my cousin that has a machine shop. He custom made some tools and we pressed it together. The front bearings are not near as easy as the rear because of the pressed fit and the shim. If you decide to tackle it, there are people here who could help you through it. However, if done wrong, it'll be the same or worse than it is now.
    Good Luck!
      I recently acquired the shop manual, and the rotunda tools to do the job, but still have yet to try it. I am so behind, like 2 months, in work that needs to be done....
