Once I got my Festiva running ('93 GL Auto) back in January the tranny was slipping in reverse and began shifting hard between 1st and 2nd(especially when cold). Checked the fluid and it was overfull, drained some out and the slipping in reverse went away and shifting was better. After getting a couple hundred miles on the car the hard shifting returned and it began to slip some between 1st and 2nd. Changed out fluid and filter and tranny worked good again with an occaisional hard shift when cold.
Took the car on a 450 mile round trip over the weekend (first trip over 70 miles it's been on in 5 years) and within a few miles of home it seemed like the car didn't downshift at stops because it slipped real bad when taking off from those stops. And now slips real bad in reverse. Checked fluid level and it was just a little low, added some fluid and on upshifts it slips some and shifts hard, still slips real bad in reverse.
Car has 209,000 miles, I've put 2K on it since January and bought the car from father-in-law who only put 2K on it the past 4 years and had no maintenance other than oil/filter changes done to the car while he owned it.
Looking for your expert opinions or at least opinions from personal experience with this tranny.
If it's time for a rebuild does anyone in the West Central MO have a person/shop you would recommend or have experience with rebuilding one of these?
Thanks in advance,
Jeff
Thanks in advance,
Jeff
