Hey, i got the #2 fuel injector on my 92 EFI 5spd, when it is sit to idle, and the computer slows down the idle speed, it idles very slow but i think it would be ok with all 4, once in a while you will hear the car's idle bounce up to normal for a second, is this fuel injector giving a bit only just not enough?
i am going to run a lucas gas additive, uper cylinder lubricant with injector cleaner, if the injector was just clogged would maybe get it working again?
And will a fuel filter that needs to be replaced, make this problem worse?
Thanks,
Sean
Thanks,
Sean
