When I ripped out the A/C from the donor Festiva, I noticed a switch (connected to the A/C wiring harness) on the gas pedal that would press when the pedal is returned to idle. I looked at other A/C equipped Festivas and found no such switch. What was the purpose of this? I thought it was an idle up switch, but heard no change in RPMs when idling. Perhaps it is and I connected it wrong? Why would this particular Festiva have a switch and none of the others?
Can anyone explain this to me?
On a side note, the condensor also had a fan attached to it; the other Festivas didn't.
Regards,
Tim
Regards,
Tim
