I dont know where these go could you help me out, or at least give me some idea, thanks
where do these go??
Top left pic is your coil wire , coil is located by the drivers side strut .
Top right pic looks like a ground wire .
Bottom left pics , maybe your clutch cable .
Bottom right is one of your battery cables .
You should see one that is grounded to the frame , the otherone would be the positive .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
The first pict with red scribble....ignition coil...you are correct.
Your second thumbnail is a gound wire that mounts to the bracket in the third thumbnail...the screw is just to the left of the hose clamp nut indicated in the second thumb nail.
The fourth thumbnail shows...
...the battery neg
...the gray and black boot go to the votage reg and output....both on the Alt
...the blue one is possibly one of three places....
1) TPS (Throttle Position Sensor) black box on the right side of the throttle
Or
2)ISC (Idle Speed Control) Cylinder shaped device mounted to the intake manifold below the TPS...has 4 hoses...2 air...2 water
Or
3)CTS (coolant Temperature Sensor) Located in the intake manifold at the No.1 cylinderJoe Lutz
The SKATE ..... 1992L 5spd
^^ the wire on the back of the Alt needs to be replaced with the yellow/black boot wire....I/m not sure where the wire that's there goes. Where does the othe end originate from?
The gray connector should snap in right under the lable on the alt.Joe Lutz
Originally posted by stefan View Post^ That might be the ground strap that goes from the passenger strut tower to the motor. Attaches to the head or something in that corner.
..I........
....N.....
.......G..
.........OJoe Lutz
