we just got an 88 and it has good spark, fuel pump is pumping good and it just turns over and over and nothing...we tried messing with the timing but we dont kno anything about it...can anyone tell me a possible problem and i need to kno where the timing marks are..thanks guys
88 festiva troubles, wouldnt start!!
check the article section i think there is a post in there about that. As for the if the aboved mentioned isn't it. check the distrib. you will be able to tell if it is the dist or not when u check timming. it will not strobe on the spark plug wire. for some reasons 88's like going through hall effect sensors.
