OK guys help me out a bit. I was at the local pull a part today and saw a 89 festy with a second cooling fan. It had A/C on it, but I can't remember it it was a m/t or an auto trans. My question is would it be worth putting it on my 93 model? Mine is a 5 spd with air. Also, is it really that much difference in swapping the radiators over to an auto one. thanks in advance
2nd fan?
mech is correct^^^
it's a condenser fan, it only cools the A/C condenser when the compressor is running. Does not affect airflow across the rad. Unless your engine is modded (bigger, turbo, etc) you don't need a bigger rad.Jim DeAngelis
kittens give Morbo gas!!
Yes the auto radiator is a 2 core one that will help keep your engine cooler, esp. if you have A/C.Originally posted by GUS View PostAlso, is it really that much difference in swapping the radiators over to an auto one. thanks in advance
