I don't want to go into the whole story but I have a Festiva with the engine cooling fan disconnected. It has the wrong thermostat housing on it so no sensor switch to turn the fan on.
The coolant sensor wire is just dangling, the fan motor lead disappears out the bottom of the car into a wire harness. I guess it is wrapped up in one of the harnesses.
What I want to do is put a toggle switch on the dash to turn it on manually when needed. If that works out, I could go with a automatic deal where it senses coolant temperature and turns the fan on that way.
What would be the best way to wire that fan motor manually and not interfere with the PCM?
The wiring is a mess on this car and I don't want to try and put it back stock.
