I did an engine rebuild on my 92 festy and i had a mind fart when i was connecting the smaller coolant and vacuum hoses and I had to just put them where I thought they went. Can anyone give me some help as far as a coolant or vacuum hose diagram? I just want to double check myself because i am burning coolant. thanks.
coolant hose diagram???
From memory...corrections appreciated
No.1 cylinder intake manifold to left side fire wall (heater core)
Metal tube...'tee'...from water pump suction wraps around engine to right side fire wall (heater core)
Just prior to the end of the metal tube above is another tee...from here to the left side of the throttle plate.
From the right side of the throttle plate to the topp connector on the IAC.
From the bottom side of the IAC to the No.2 cylinder intake manifold.
If your burning water....sources could be:
Cracked block
Bad Head Gasket
Bad Intake manifold gasket.
Bad gasket at the throtle plate.
Internal leak in the IAC
Maybe the radiator cap is shot and the water is steaming off and not burning.
Do you have white smoke at the tail pipe?Joe Lutz
The SKATE ..... 1992L 5spd
thanks for the quick reply. I do have white smoke at the tail pipe. I also have that goofy looking thing. they call it an air controller at napa. I think that is my worst problem. there are 4 tubes comming off of that alone. is there a hyperlink for a diagram. I appriciate the response but I am kinda confused. Thanks again guys
