I'm wondering if I should change the Auto transmission fluid on this Aspire. I was told that the new fluid has detergent that may cause it to start slipping. I'm big on doing service on a car, however if it can cause transmission falure is this a good move? The car has 120k probably never been changed but shifts good.
Second question if i do change it, should I use dextron 3 or mercon v? This is an automatic transmission.
All advice appreciated!
Thanks,
Mike
Thanks,
Mike
