I'm guessing this is the throw-out bearing but I figured I'd run it by the experts:
1993 5 speed
Rubbing or grinding noise when car is in gear and clutch is engaged. Stops when clutch is disengaged. Also occurs with transmission is in neutral and I've not got the clutch to the floor.
Otherwise, shifts fine and runs well. 42 mpg on the last tank, pretty considering the hills I have to climb.
Time for a clutch kit?
1993 5 speed
