I am having some issues with the a/c in the festy so I was looking for a little help. I am having a lack of cold air at an idle. I have the factory manual and gauges etc, but what is throwing me off is the fact that I am using 414b freon. I don't know what my pressures should be with this. Does it run higher or lower than r-12? I know these cars use a TXV metering device so charging by superheat is difficult( if I even knew what the proper difference was). Also while driving the cold air goes in and out(like the TXV working) does that indicate a low charge or another problem? Any help would be greatly appreciated guys.
A/C help
The system was designed to work with R-12. You will get unsatisfactory results with anything else. It costs alittle more, but use R-12. No more problems.'89L 110k mi. BP/G swapped
'90LX 68k mi. wrecked 12/14 RIP
'90 F250 4X4 108K mi.
'13 Kia Rio 5 LX 70k mi.
'18 Kia Soul 40k mi. Daily
'64 Studebaker Gran Turismo Hawk
'66 International Harvester pickup
Because changing to 134 requires pulling the system down and flushing. R12 uses different oil. 414b is a replacement that will mix with both and their oils. That way I don't have to evacuate,flush and change the dryer. I can just add on top of my current r1293 festiva aka "the sexy"
04 blown GT stang
99 wrangler (in the middle of a 5.2 swap)
Yes the fan works correctly. It acts like a charge problem(either to much or to little) or maybe air in the system. I guess I am just going to have to pull the whole system down and evacuate it to check for leaks then start from square one.93 festiva aka "the sexy"
04 blown GT stang
Mostly GM. Refrigerant critical temperature is mention as is much more info. Maybe you can find a clue here. http://www.imcool.com/articles/airco...500_NoCool.php
