Caster off on one side
  • Caster off on one side
    Having problems with the Aspire... makes it real interesting to drive to say the least. They call it tramlining.. basically its one wandering fool. At first I thought it was the new tires I put on. But it has always existed with different tires just at different degrees of severity. I had a alignment done and they got to line up good, the caster on one side was flagged though. I've read that if caster is negative it will cause it. I don't think overall it was negative though. (Sorry don't have the paperwork on me).
    My question is how can the caster be adjusted? Did I tighten the sway bar to much? The control arm I put on so I know its not bent.
    91 rusty Festiva 260k
