I have a 96 Aspire, automatic with A/C. Getting only about 24 MPG. Tires are inflated; air cleaner OK. Any suggestions on how to get better mileage? Thanks.
Aspire With Lousy Gas Mileage
First thing I am going to replace on my 92 Festy is the O2 sensor, just a thought. I am getting that code indication and I know from my other vehicles that will make a difference if it is bad. I believe you have two, one before and one past the cat, someone please correct me if I am wrong. And maybe see if there are any stored codes for clues?Remember "I" before "E", except as in Budweiser.
my G/F has the same thing; solution: remove sparkplugs and inject SeaFoam, replace plugs and let sit overnight (at least 8 hrs). Blow the stuff out and reinsert the plugs. run car normaly. milage will improve within a tank. also I've found that STP fuel treatment bumps the milage by 3-4 MPG, especially when used with NON-ethanol fuel.Trees aren't kind to me...
Originally posted by FestYboy View Postmy G/F has the same thing; solution: remove sparkplugs and inject SeaFoam, replace plugs and let sit overnight (at least 8 hrs). Blow the stuff out and reinsert the plugs. run car normaly. milage will improve within a tank. also I've found that STP fuel treatment bumps the milage by 3-4 MPG, especially when used with NON-ethanol fuel.
If you are talking about the aspire....how big are the tanks on those?"FLTG4LIFE" @FINALLEVEL , "PBH"
i can get a 3 pack of STP for $3, so it's worth it for meTrees aren't kind to me...
If the engine is running that bad it should not pass government emissions inspection?
I'd jack up each wheel and check that they are turning freely.
It could be something mechanical like grabbing brakes (how's the steering?) or worn bearings (any noise?).
Does the hand brake release properly? The linkage outside the back wheels can get rusty and stick.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
^^ a common issue for sure, but that didnt fix the milage on my G/Fs aspire. i'm betting on sticking rings, check your compression (engine at opperating temp)Trees aren't kind to me...
