I bought my '92L 5 speed several years ago for $190. Good buy, but I'm a procrastinator. I also do not have even moderate electrical skills, so after replacing the gas tank and fuel pump, and looking it over, it still didn't start last summer. I finally broke down and hired a mobile mechanic to come troubleshoot it. Found that the inertia switch was UNPLUGGED ! and the VAF was bad. Wiring was okay otherwise. (I had thought the wiring for the inertia switch was "inside" the body, which is why I didn't notice that!)
I put in my VAF from Luxstiva's old B3 (which tested fine) and upon fuel pump pressuring up, instead of no fuel in the engine compartment, I received TOO MUCH! Turns out it was spraying from one of the injectors. I remember I did have some problems fitting one of the new injector O-rings in when I cleaned all that up last summer.
Yesterday I fixed that! Took about an hour and wasn't too hard.
So she starts, but there is a tapping or knocking sound from the head area. I figure it is either a rocker arm or a valve, but I really don't know this. She also seems to be running "hot." I wonder if there is an overheating or head gasket problem?
After running only a few minutes, I removed the radiator cap and a cup or two of fluid spurted out. Hmmm.
If this is going to be a head removal job, I'll just prep my second B6 for its new home.
Any other ideas on what could be wrong?
Karl
PS: BTW, she felt nice and tight upon limited yard manuevers! She should for only 70K miles! So far I have just under $600 in her: new gas tank, fuel lines, and the mechanic, who showed me what he was doing and was worth the $160 or so for just under 2 hours.
Karl
