Headlight problems
  • Headlight problems
    On one of my festivas, The headlights go off when you push the signal arm down, but if you pull up on it for a temporary bright light, its works. Any body got any ideals before I tear it down? Thanks
    Did you try hosing it down with electrical cleaner? Maybe dirty contacts.
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      loose contact-or dirty like monsoon mentioned,ground maybe??
        Thanks guys, I will try these things
          Also...the connector to the switch assembly may be loose. And, their is a headlamp relay that may be on its way out.
          Joe Lutz
          The SKATE ..... 1992L 5spd
