Rear quarter window help needed
  • Rear quarter window help needed
    Hi all. Well, I made the mistake of taking my festiva in to have the windows tinted. Aside from doing a poor job on the tint, they managed to create a few problems that I didn't have before. They broke my cargo light (while installing new speakers), created an annoying rattle in the front passenger door, but worst of all, neither of the rear quarter windows will stay closed. :angry4: Now I know why they wanted to be payed up front. *sigh* Lessons learned......
    I had a moment where I thought about taking it back in there and making them 'fix' it but then sanity took hold, and I realized that they would probably screw it up even worse, so I abandoned that thought. LOL
    So now I have to figure out what's wrong with the windows and why they won't stay closed. I think that they installed some plastic washers that weren't there originally, and that they may be too thick. Anyone have a picture of how the hinges and latches go back together? I know that the parts that fit together through the glass have a rectangular shape that has to line up, but since I didn't take the thing apart, it's tough to know if it's back together correctly. Any help (and pics) would be appreciated!
    Laura Z
    You know? I tinted my own windows and they turned out perfectly..I put all the washers where they supposed to and BAM! my windows wont stay closed either? Well, I got tired of making adjustments for about an hour to no fix in the near future so I just zip tied the latch together. When you think about it, I never use them windows and its an added security to have them tied...what you think?
    Ski
    Ski
    1986 Ferrari Testarossa
    2002 BMW 745i
    2002 BMW 325i
    1989 BP'd Festi :p
      Hi Ski,
      Thanks for the suggestion. As tempting as the zip-tie fix is, I would really like to get the windows back to functioning properly.
      Maybe it has something to do with the original rubber washers being compressed one way for so long and then getting put back in a different position. Not much of a difference, but just enough to cause too much tension on the latches. Hmmm, maybe buying new rubber washers somewhere might do the trick? Ones with more 'give' and less 'memory'?
      Thanks for your thoughts!
      Laura Z
        the little tabs that the lever snaps over did not get broken off did they?
          The tabs are intact
          But I wonder how worn out they are. I can get the windows to latch, but drive over a bump (not even a big bump) or close a door or the hatch, and they pop right open now. Not cool, especially in a drive through car wash!
            Hopefully this will help, the washer is on the outside of the very dirty window..hard to get the digital cam to focus where I wanted it to.
            Let me know if you need a different view...specific part or whatnot. perhaps the camera will even do it!!
            92 Festiva L stock with wheel upgrade...The Mater (Sold)
            '66 Galaxie 500 428 FE...Friend of OPEC
            '68 Mustang Coupe
            '63 Galaxie Country Sedan
              Rear latch from the shop manual
              LauraZ
              This scan from the shop manual may help.
              CharlieZ
                Thank you!
                Edudu77 and CharlieZ, that's just the info I needed and I really appreciate you taking the time to post it.
                As it turns out, these guys put a rubber washer on the inside, in addition to the one on the outside.
                Hey, is it also supposed to have a washer on the outside only, at the hinge points also?
                Stands to reason, but just making sure.
                Thanks again all!
                Laura Z
                P.S. I bought a set of shop manuals on ebay, but they haven't shipped yet. Can't wait until they get here! LOL
                  The hinges appear to have the washers inside and out...to shield the glass from the metal hinges, I suppose. You're welcome.
                  '68 Mustang Coupe
                    I had my rear windows out twice so far. The first time, I had the same problem you have. My mistake was not having the washers in right. The washers are supposed to be on the glass. If you look at your windows, you'll know what I mean. The only thing touching the glass should be the washers.
                    A tip:
                    Once you get your windows back in, latch them tight. Then take a screw driver and loosen the screws by the doors up just a touch. You'll feel the glass move ever so slightly. Tighten them back up and they should work fine.
                      edudu77 is correct. Inside and outside. Another scan from the manual may help.
                        Once again, you guys are awesome! Thanks! I'll update when I get this done.
                        Laura Z
                          Shoot, now you did it! Now I have to go and look at my windows! hahahah
                          Ski
                          2002 BMW 745i
                          2002 BMW 325i
                          1989 BP'd Festi :p
                            No more Pop goes the windows!
                            You guys are the best! Thanks!
                            Laura Z
                            :wav:
