Installed clutch.Now it is time to refill the tranny fluid.I took the speedo cable out.I took the 10mm bolt out , but,I cannot remove the piece to put in fluid.I tried to fill with the "plate" ( little piece speedo cable goes in to) on , but,nothing.Any ideas ???
Tranny fluid problem...speedo hole
Common problem!
You need to spray the outside of the "piece" with PB Blaster.
Let it soak a few minutes and spray it again.
DO NOT get any inside where the cable mates to it.
Now try to work it clockwise and counter-clockwise.
Tap it with a small hammer first clockwise then counter-clockwise.
Be very gentle this part is prone to breaking!
Once it is moving freely you can try to remove it by turning in either direction while pulling up on it!
Should work!'93 Blue 5spd 230K(down for clutch and overall maintanence)
