2 dumb questions...
  • 2 dumb questions...
    car is 1991 festiva B3 engine stock everything. i am in connecticut.
    1) when i took off the exhaust manifold from my son's festiva i found 5 gaskets - one gasket for each exhaust port and one long gasket that handled all 4 exhaust ports.
    question- what is the correct configuration? 1 long gasket, 4 individual gaskets, or 5 total gaskets?
    2) my son's B3 block is leaking coolant to the outside world near and at the freeze plugs in front - actually NEAR the freeze plugs and IN the freeze plugs - bottom line is that I need a new short block. the old block has rusted so badly that coolant is leaking out.
    question- is an engine block from an Aspire (say a 1996 or so?) interchangeable with a 1991 festiva engine block?
    i do believe they engine blocks are interchangeable the aspire has the same engine as the festiva and you might want to put your location up in case there is someone near you who can help...
    1989
    Ford Festiva L
    Automatic
      fully impimented OBD2....96-97 has a crank position sensor...but i think the block itself should be alright to use.
      There sshould be a multi-layer metal gassket for the exhaust manifold...but the last time i checked not each individual port...
        For what ever it's worth, the manual shows one metal gasket.
          Originally posted by rret View Post
          ... question- is an engine block from an Aspire (say a 1996 or so?) interchangeable with a 1991 festiva engine block?
          Aspires come with a roller valve train. I'd use the Aspire head too.
            I do believe you will run into a drive belt issue since the aspire has serpentine belts and the festiva has V-belts and the differences in crankshaft pulleys
            I am the original
              We installed a used Aspire B3 in a 90 Festy with a swap of the manifolds and pulley system. This included reusing the Dealer installed A/C system that was on the Festy,with no problems at all. It was a straight swap with no issues that went easier than installing a crate engine from FMS.
              Michael
              Have owned 9 so far
                I'm a little slow with the reply, sorry.
                The old exhaust gasket had burned and rusted to the point where it fell apart. It's supposed to be one piece.
                Your coolant leaks are from rusted freeze plugs. Just replace the plugs. The block is aluminum; it won't rust.
                '92 Geo Metro XFi
                '87 Suzuki Samurai
                '85 F150, modded 300cid
                  ^ the block is aluminum?!
                  who let this guy on the board? lol... its a cast block. Go stick a magnet on it.
                  aspire B3 should swap as long as you use the mani's and pulleys from the festiva, just like m715 said.
                  ~Nate
                  Current cars:
                  FOTY 2008 winner!
                    Originally posted by BigElCat View Post
                    I'm a little slow ....
                    Really so all that feric oxide is coming from were?
                    Then why use steel freeze plugs?
                    You must have the creationist block the rest of us got the Standard Model!:p
                      Originally posted by Pu241 View Post
                      ..You must have the creationist block the rest of us got the Standard Model!:p
                      time to go to the Arena, not all creationists are slow
                      (I am a creationist, and perhaps I am slow, but I think not all of us are!)
                      BTW: Disclaimer: no offense meant, and none taken. I can respect your views as long as you can respect mine..
                      ~Nate
                      Current cars:
                      FOTY 2008 winner!
                        I'm a creationist too. I'm slowly creating a nice Festiva.
                          even using an OBDII motor will work you just wont plug a harness into the crank position sensor.
                            Yeah that's what i was getting at....the motor would work but don't be allarmed when you find a Crank postioning sensor.
                              I have an aluminum block too!!
