im trying to get my friends 86 mr2 started, it sat for 7 years so i took the fuel rail off and want to make shure the injectors work good. is there a way to test them? also how much fuel press should the pump put out?
how do i test injectors
Mike, AKA the sasquatch
1990 LX, bp+T/g25mr, 9psi dynoed at 194HP, turbonetics t3/to4e 57trim, haltech E6X standalone, 550cc injectors, turbosmart wastegate, synapse BOV, walbro 255 fuel pump, aeromotive FPR, AEM wideband, 3 inch exhaust, huge FMIC, 9LB flywheel, 6 puck clutch and way more parts that im forgetting i installed lol...Tags: None
check the resistance across the terminals, assuming their high-impedance should probobly be somewhere in the 12-14ohm range, if you have a manual it should specify or perhaps you can find the info online.
take a 9v batt, run wires to each of the injector terminals... it should "click" as it opens. hold it open (keep the battery connected), and spray carb cleaner through it, make sure you getting a fairly decent spray out of them... as far as i know thats about as much as you can do at home.~Nate
Current cars:
FOTY 2008 winner!
thanks. i did do the ohm test, but not the 9v batt test and they are back in the car so im not taking them out any more...Originally posted by skeeters_keeper View Postcheck the resistance across the terminals, assuming their high-impedance should probobly be somewhere in the 12-14ohm range, if you have a manual it should specify or perhaps you can find the info online.
