Hey my 88 LX carbed says it redlines at 6000, but i know first hand it will rev past that, so what is the "redline" of my car, i know it deff looses power after about 6200 rpm but is this because of the low cfm carb? the design of the head won't allow the air to get the the cyl fast enough at the speed? maybe a combination of the 2? or is it something completely different, i would love to have a high reving b3 lol
Red line?
Red line?
(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
New: Tires, Axels, Front Wheel Bearings, Fuel Pump, Valve Cover Gasket, Carb Rebuild, Timing Set, Belts, Shoes, Distributor, CapRotor, Wires, Plugs, Coil, Grant 11" Steering Wheel, 3700 Watt Stereo System-6 1/2 Infinity speakers, Infinity tweeters, Almani 12" subsTags: None
Yeah thats what i mean the redline on the tach, but thats why i started this thread, what really does happen after the manufactures suggested maximin engine operating range haha. Im sure the u could actually go higher then what they suggest because they know people are going to take it up to redline and they wouldn't put the the redline at 6000 if any higher then that would cause damage. For instance lets say your car is a bucket, and ur rpms are water, and the more water u put in the bucket, the faster you could fill something up, but if any water spilled out of the bucket it would do damage to the bucket. So of course the bucket makers would suggest filling up the bucket to a certain level that is not close to the top, because they know if they tell you to fill it up all the way to the top there is a chance you could spill and do damage to the bucket lol. So wow my brain works weird but does that make since?(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
oh i do belive that haha thats for sure, and why does my sister call my festiva a bucket? lol actually she named my festiva, she is in shape and she makes fun of my cause im in shape too, but a different kinda shape (hey round is a shape right) and the suspension is a little worn so when i get in it, it leans just oh so slightly, lol, so its not the festiva, its the FATstiva lol(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
The redline shown on a tachometer is the point at which you should not exceed that engine rpm under any normal circumstances. Engine rpm in most 4 cycle, valve in head engines is limited by the ability of the valve train to follow and stay in contact with the camshaft. If you choose to rev past the point of valve control (red line), you can crash a valve(s) into the piston(s) and the results can be anywhere from nothing/minor to catastrophic. Depends on the engine.
Computer controlled engines often have fuel or ignition cut offs that prevent the engine from being twisted into self-destruction.
B-Series' tend to do this, once the valves float...Originally posted by Mike McKown View PostThe redline shown on a tachometer is the point at which you should not exceed that engine rpm under any normal circumstances. Engine rpm in most 4 cycle, valve in head engines is limited by the ability of the valve train to follow and stay in contact with the camshaft. If you choose to rev past the point of valve control (red line), you can crash a valve(s) into the piston(s) and the results can be anywhere from nothing/minor to catastrophic. Depends on the engine.
Been there, done that.
I've been to 6500 a few times in my '93 carbed Kia, but as its not done 70000 (miles not Ks) yet I'm keeping the revs down until it's run-in.
I would've thought carbed engines would be limited by valve bounce, and as these are non-interference engines - the sky's the limit.
Simon the BP's redline is 7K so that's not too bad. I believe they have fuel cut at 7K as well, and the GTX BPT ECU cuts around 720089 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
good call!89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
