What is the best way to go about replacing the fuel filter? Can you just go with an in-line filter or is there a better or diffrent way? I'm open to any and all suggestions. Thanx, Perry
Fuel Filter Replacement
I would imagine that the best way would be stock replacement..
click Stock Parts
click Air Intake, Fuel Delivery and Ignition
> takes you to a list of parts, including fuel filters for both carb and efiJoey Richard Jr.
1991 Ford Festiva L; died but donated all her organs
1988 Ford Festiva LX; EFI swapped in...actually everything swapped in
Quality is Job 1. Together, We Can Save Lives. Ford.
You could also go to your local Advance Auto and pick one up. The purolater # F54666 fuel filter (fuel injected) is usally available at your local store, you can pick it up and not have to pay for shipping, and it will save you a few dollars as well. While you're there pick up a Haynes repair manual and it will tell you where it's located (driver side on the lower part of the strut tower) and exactly how to do it as well right in the first chapter of the book. Good luck!90 Festiva with Brand new B3, 5spd
92 B6 Festiva, 5spd
