there is a guy local that supposed to have a aspire swap but he don't have the rear axle just the hubs and drums , but everything for the front minus tie rod ends , anyway will the hubs and drums go on my festiva axle ?? and do i need new struts to ?? i gonna get this for $125 is that to much any pics could probably help , thank all you for all your help , it's much appreciated
rear brake swap
The hubs (spindle) will not bolt up to the Festiva axle. The bolt pattern of the 4 bolts is different. You can use your struts unless they are worn out. The Aspire front struts have slightly more resistance (stiffer) and the rear (usually) have a slightly higher spring perch, but your Festiva's will work. $125.00 sounds reasonable to me.You gonna race that thing?
Your gonna need that rear beam and some 4x100 wheels. Might as well change the front pads while your at it. 125 is very reasonable for loaded spindles/calipers/pads. I'm getting ready to buy another aspire swap for 130 myself.---------------------------------------------------
According to car-part.com the junkyard down the road from me has an aspire rear axle assembly for $125. Probably includes the brake hardware. I think Im gonna get that when Im ready to swap.91GL BP/F3A with boost
